I have been struggling with the parking brake not holding for some time and I kept thinking that the brakes weren't adjusted right. After adjusting the shoes and the cable tension, it was still a no-go. Then I found this:
Notice how the anchor pin plate (I think that is what it's called) is not in the groove between the two shoes like it should be. It came out of the groove and is on TOP of one of the metal tab of one of the shoes:
This happened on both the left and right wheels. Here (in green) is pin in the groove that it should be in, the red is where it was when I found it:
On both sides, it had slipped out of the center groove that it is supposed to be in. This made it so that the parking brake lever would not actuate the shoes when it should. It looks like the metal tabs on the shoes are made of soft metal so I don't know if this would have caused it. Any ideas? I know that even thought it's fixed now, it's only a matter of time before it happens again.
