reklund
I replaced the orings twice today, once first thing this morning, and again at lunch. Still leaks.
I investigated further, and was actually able to see fuel bubbling up out of the threads in the cylinder head where the injector screws in. It seems the injector itself is the source of the leak, not the return system. As I said, I hadn't experienced any of the usual symptoms of air in the system, and the way mine is leaking supports my little theory...
I think the injector is leaking somehow- wherever the case is assembled with all the goodies inside, it doesn't seal ( Im pretty sure that's down near the nozzle, which is sealed to the combustion chamber with a copper washer). The cavity between that copper washer and the threads in the cylinder head has filled with diesel fuel, and the fuel is bubbling up past the threads.
I immediately called Ken at DPS, who didn't hesitate to stick another injector in the mail to solve the issue. Great support, as usual, from DPS.
Maybe this time, I'll get the leaks fixed....
Ryan
Ryan
