An injector that has a weak spring pops open early causing a fuel knock. Now for any material going thru the oil pump thats just not going to happen. We have a screened oil suction head. For something going thru the filter breaking up thats not possible either. The oil supply from the filter goes directly to the main oil galley. So those pieces can't have gone thru the oil system. They came from the lift pump, the oil refills or the valve seals. I can't see the valley pan gromit being made of any material that looks like this.
do you still get a clean burn with this? no smoke since its not leaking?
