DB2 Pump Numbers 5070 & 4817
What are these Stanadyne pump numbers? As I remember the 5070 was my turbo pump I bought from Texas shop but the 4817 is what I don't know what it is. I only have a 7.3 motor if that helps. Mel, what can you do with the 4817 pump as far a Moose pump goes....
6 Nebraska IDIs
What about DB2-4814
I believe its a 7.3 pump, just not sure which one, the high altitude higher HP pump or the other one.
I think Im due for a pump on my low mile truck because it sat for so long, and Im gonna put a turbo on it, so I figure I might as well just put the 7.3 pump on it.
I believe the 4817 is a high altitude 6.9 pump.
6 Nebraska IDIs
Answered my own question, did some research and found a very interesting and useful PDF with all the International and Stanadyne part numbers on it.
Well the pump I've found is that DB2-4814, ZKK991723. Which is a manual shut off pump. Can I use this pump on my 6.9? I can get it cheaper than getting one from MWFI, and this one's rebuilt from Stanadyne.
Can I swap my current electronic shut off over to this pump?
6 Nebraska IDIs
hey bud, that 5070 pump is a 93/94 ZF5 7.3 factory turbo pump.
the other one is a 90 Ford Eaton pump.
So what is the Eaton pump??? I have never heard of that type of pump. Mel I may be needing a Moose pump. What can you do with the 4817 pump....
To the best of my knowledge, there are only two "physical" pumps - the one for the 6.9, and the one for the 7.3 in terms of build. All those part numbers are mostly related to calibration settings, and accessory mounting options, such as the style of the throttle lever, etc. I can make a Moose Pump out of any of them.
