Dana 60 kingpin?
Fordfarmer123
Westfield
I got a 93 7.3 idi
And I have have 87 parts truck with a king pin axle. Is it worth swapping ? Are these axles better then a ball joint one?
are you saying you already have a ball joint D60 under your truck and are contemplating swaping it out with a KP D60?
Unless you spend a majority of time on fire trails and very little time on dry pavement, will you bennefit from the swap.
if you currently have a D50 IFS and is remotely toying with the idea of swapping in the D60.......stop thinking and just do it. the ability of not needing 40 acres to do a U-turn is priceless.
Dieselcrawler
Professional wrench holder
Quakertown Pa
They both have their strengths and weaknesses. Anymore I want the ball joint axles. Stronger parts and better brakes
BagdadRon
Staff online
