cruise control
rockcrawler_101
tres pinos ca
I just got done doing my cummins swap into my 86 f350. I got everything working but the cruise control. It worked before the swap. I swapped over the vacuum dump switch. I adjusted it in all the way in so you cant really see the white part. I did have to put a new speed sensor in and had to wiring it in (sense i had lost the other wire connector) I got one from newer model. The color on the wires where different and i wired it up with the black wires on both and the grey to green. I dont know where the cruise control gets its power from. all the wiring diagrams i have seen dont show it and my chiltons doesnt show any for the cruise control. I have Vacuum at the canister but i havent tested how much it is. Any help would be great thank you.
rockcrawler_101
tres pinos ca
thanks this is perfect. i noticed that some power goes through the blinker relay and i put an led one in there and that might be messing with it. When i get home i will have to check it out. Thanks again!
