Cracked Valve Seats and Pre-Cups
WarNose
Bay Area, CA
Upon inspection, the machine shop says that between both heads there are 7 small cracks in the valve seats and each pre-chamber has multiple small cracks. He says the cracks aren't a super big deal and thinks that it would be hard to find 6.9 heads in better shape. What do you all think?
Sounds like he’s dealt with idi heads before. Almost every idi precup I see is cracked, just make sure they don’t go past the fire ring, the valve seats can be an issue depending on how severe they are but it really depends on your machinest’s judgement.
Only time I’ve seen it crack on the outside diameter of the precup is when a head gasket was blown from it lifting a head. The precup had room to drop down and flame front got around the edges.
Your machinist does realize that the valve seats are replaceable, right? What's the big deal with bad seats?
Macrobb
North Idaho
No matter what you do, the engine will run. IDIs are amazingly tough, and things don't have to be perfect. Precups always crack. As long as you don't have any chance of coolant leaking through cracks in your head(or combusion gasses coming out), you should be OK...
DrCharles
West Plains, MO
This may be a silly question, but could the seat inserts be coated with green Loctite or whatever they use on cylinder sleeves to retain them? If it's a tight press fit there shouldn't be a leak if the insert completely covered the hole into the water jacket.
Will cali fall into the ocean tomorrow? Keep your egts below 1200* and dont overheat the engine is about all you can do. If I was doing the rebuild and the cracks were acceptable and you felt uneasy about them I would use a better set of heads. I wouldnt have any issue running cracked pre cups on my own trucks, but you want your customer to be completely at ease with their engine. Id say in your case if you feel you cant trust the heads the way they are now then pay the money now to make it right.
dogdanblue
