Correct Inj Pump #
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
Does any one know the correct # for a 94 turbo pump -we just got one from Deisel service the # is DB2- 508 or Db2-509 the last 3 is not clear.
The pump thet came off had a Ford 3 starting with FT3.
Thanks Mr Bill
sassyrel
iowa
5069--or 5070--ones manual trans--the other auto--and dont rem which!!!!!!!!!!!
Diesel JD
Gainesville, FL
Then it doesn't matter because you could just switch over the auto trans goodies to the new pump right? Also I think the one for the factory turbo motors that you want is the only Ford/IH pump to have an external fuel delivery adjustment screw, if I'm not mistaken.
The auto trans pump I bought from DIS was the 5070 model if that helps any.
