Cooling mod
Fordman1920032003
Arkansas
I've been considering the 6.9 cooling mod for the heads for my 93 7.3. I'm looking for input for if it is worth the trouble. I heavy haul most of the time when I drive it. I've already ordered studs, stage 1 injectors, and intercooler. Still on the fence on turbo and ip.
chillman88
Central NY
I would do it if I had the heads off, but I wouldn't pull the heads JUST to do it. If you're doing studs you'll have them off anyway so I don't see any reasons not to. It's not very difficult.
It’s totally worth it. I run the shop truck with a big pump and high egts in 110+ Texas temps with no fan or fan shroud with no overheating issues, you won’t do that with half the coolant passages plugged.
lotzagoodstuff
Carmel, IN
What's your temps look like with any load/towing? My 7.3 N/A never got hot without a fan unloaded, but you are talking lots more fuel/boost. Either way: I'm impressed with the improvement that opening up those passages makes.
If I put a fifth wheel behind it I put a fan on and don’t have it get above 200. With a couple core engines and transmissions (say 2500-3500 lbs) in the bed it sits around 200 and gets up to 220 if I’m passing everything on the highway.
Fordman1920032003
Arkansas
Interesting, I have no intentions of driving without a fan. When I pull, I need the utmost in reliability. Engine temps and egt has to remain at a safe level. Hopefully once I pull the trigger on a bigger pump and turbo, I wont have to drive it on the floorboard for hours at a time.
My water temp is pretty much the same with or without the fan when empty so I just left it off to get better mileage and less wear on the water pump. I don’t think you will be flooring all the time after you upgrade, most driving is done within a quarter throttle, and with my 38’ travel trailer hooked up I can still roast the tires if I take off too quick from a line, it’s a big difference from a basically stock IDIT setup.
130 pump with a stock turbo at its mechanical limit, 17-18 psi intercooler and over double feed pressure.
Bo17
