NapaBavarian
Dually driver 6.9
Every morning my clutch works great, then when things warm up the clutch won't release...is this the pilot bushing? Bad hydraulics? A problem for "The X Files"? HELP! I can't take it anymore!
Joe Mc said:That is the classic symptom of a cracked firewall. As the truck and the weather gets warmer it gets harder and harder to shift gears. At least, that is how I read your problem.
Before I installed the large firewall repair kit from Ford, I had to turn mine off before I could get it in reverse if I had been driving very far. It would shift pretty good in the morning with the truck cold and even better if the air temp was 40 or lower.
sle2115 said:Or checked the firewall...sounds like mine before applying the cracked firewall kit.
