NapaBavarian
Dually driver 6.9
yup, got the hiem joint thing done long time ago too I don't want to throw too much energy at this transmission as it needs to go the way of the dodo bird to make room for a 6 speed
hahn_rossman said:I just went thru this headache myself, and in the course of scouring the archives I came across a post (mel's?) that noted that firewall cracking is a symptom of the throwout bearing getting harder and harder to slide along the input shaft. Eventually you start breaking the firewall with all that stomping on the clutch pedal. My pilot bearing died and when I took it apart (big sigh, and laments about 4WD) removed the shrapnel that it had become and replaced the clutch, pressure plate, throwout bearing, and pilot bearing, I was amazed at how easy the pedal is to depress. If you haven't driven a truck with a recent clutch job, or one of those fancy greasable throwout bearings I don't think you can imagine how easy it can be. Good luck, and by all means unbolt the tranny from the bellhousing.
