CDD April 2019 Product Releases and Product Updates
Greetings Oilburners! Today I am happy to announce some new products for April 2019 from Classic Diesel Designs:
-CDD intake hats for intercooling, comes with hat gaskets and hardware. These hats make for a great base to build your own intercooler setup for your your IDI, while still retaining the stock intake manifold. This hat base is 2 1/4” tall, if your setup requires a lower profile design, we will custom tailor the dimensions to fit your needs, no extra cost. $300 shipped
-IDI injector o-rings and copper washers are now available from us in individual sets of eight. Copper washers are $10 shipped, and injector o-rings are available in viton ($20 shipped) and nitrile ($15 shipped).
Some updates to our existing product line:
All custom turbos with ceramic coating package will now have the CDD logo coated into the hotside in our high temp matte black or silver as seen here:
Our downpipe and intakes are temporarily discontinued. We will have version 2.0 of each out next month, that will do the same jobs of the original kits, only better!
All our harnesses will now come in a custom 500 degree loom sporting the CDD shop colors, no change in pricing:
As of June 1st 2019 these price changes will be made:
Billet check valves $20 shipped, three for $50.
Stock injectors (except G codes) will be $425 shipped, G codes will be $450 shipped and stage ones will be $495 shipped.
Thank you Oilburners for your continued support of CDD!
Wes
Saev
WA
You happen to sell a crossover pipe/s?
Jake60
New Jersey
Wes
Even if you don't have an IDI that intake hat is worth the price as a object d'art. Beautiful welds there brother.
tjsea
Lickdale, PA
Are the stage 1 injectors the ones you were modifying with the 3M nozzles? How did testing go with them? What are the advantages over stock injectors?
I should be pulling out the 3m injectors from the shop truck soon for an update, the stage ones are a G code nozzle that is set at a lower pop pressure after going in and cleaning up the factory finish on the pintle and nozzle by lapping it by hand. The lower pop pressure pulls a bit more fuel out of the pump but without compromising the spray pattern, same concept as the 3m just not as extreme.
That poor shop truck will be able to disassemble itself pretty soon. Sometimes you just have to feel a little bit sorry for the test mules.
lewisstevey7
