CDD 110 pump.
Thewespaul
Bulverde, Texas
You will pick up quite a bit from the other upgrades. Between the intercoolers and larger turbos you will gain quite a large amount of air density which equals power, and be able to use the power from the larger pump for much longer when pulling loads, not having to back out early because of egts or boost numbers.
frankenwrench
overkill is under rated!
Weatherford tx
That will help a lot cause I do ease out quite a bit with some heavy loads. We do have some slight hills I like to slow down to 55 and drop to 4 the gear in. But I did notice some small oil and water puddles.the other day and I di have slight weeping from the backs of my heads on those year and some change head gaskets. Kinda ticked me off so replacing them before the studs go in with the rest of the upgrades
frankenwrench
Weatherford tx
Cruising down i-20 empty with the music loud and not paying attention I noticed some cherries and berries lit up behind me. Looked at the GPS and realized I was going 90. Bout sh*t myself. One, cause I barely had my foot in it, two, I knew that I would be lucky to get off with a ticket in that construction zone in a 65 zone. Long story short, he wasn't after me. Had to replace my steering column a few years ago with what I had in my yard and in doing so gave up cruise controle and tilt. I think I need that back now. Lol. Anyone got one for a 91 with cruise? I'd love the tilt, but at this point not a deal breaker.
  • Like
Reactions: hce
