What can I do to remedy this mount. I really don't wanna spend $133 for one piece of rubber
Is it just the rubber cab-mount cushions ??
If so, complete sets can be had for very little expense, even urethane ones.
There are two weird ones on the very front that have a threaded center and are a
to get out/loose.
There is absolutely no need for that threaded center, other than when on the assembly-line.
It has been a while, but I believe I drilled out those threads so a bolt would go straight through.
I have had zero issues with the spacer-type lift; but, when time allows, I am going to actually remove the cab-mount pedestals from the frame and re-work them to be a LOT higher than the factory position, thus negating the need for the spacers.
If I get it up there high enough, I may even put a set of saddle-tanks under the doors.
