I'd be in on a set also. At work we have all the machines, but I don't know how to run them. I work for a hydraulic cylinder manufacturer and we make cylinders all day with aluminum and steel components that have to seal together using o-rings. I'm guessing this will be all right, but agree it needs to be tested. I'll check with the engineers at work and see if we do any special tolerance for Steel to aluminum sealing versus steel to ductile. We are also sealing up to 3,000 PSI where these caps seal what 15PSI at best?
I'd definitely take 2 sets if you made them for the ATS style turbos with the 3 nippled caps and the dead end cap for the turbo area.
If you don't mind checking with your engineers about tolerances that would be great!! I work nights so by the time I get into work our engineers have already left for the day.
