BIG RED REBUILD
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
got some more work done today :sly My dad gave me a hand to which was nice(thanks dad).
IT'S OUT:Thumbs Up
Tomorrows plan is to drop the tanks and pull the axles and all the little brackets so I can start wiring the frame and paint it:slycookoo
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
well no up dates really, but I did get a deal on some 2 1/2 ton 2wd axles with a two speed rear. So i'm playing with this idea for red. I'm building her for the high way and hauling so I think this would be sick:sly
Only thing I need body whys is the dually fenders :D
bike-maker
albany, OR
I had an old F600 for a while with a 18,000 GVW (3 ton?). Had a Rockwell 2-1/2 ton rear end with 6.80:1 gears. HUGE centersection. Looked like a 9" Ford rearend, just twice the size. The medium duty front ends are usually too wide to fit under a standard width front clip. The older medium duty trucks made up for a lack of horsepower with really steep gearing (like 6.40 or 6.80:1). The 2 speed rearends didn't gain anything, the second speed was an even lower gear. If you can find a 4x4 version, they're even steeper; I think 7.40:1. Not being able to find acceptable gears is why I abandoned the project.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Go for it.:sly If only it were as easy in the garage as on the computer.LOL D60 the front and get wheel adapters.;Sweet
88beast
pa
looks good since old blue is already a mud truck a 2wd hauler is youre next step
the 2 speed rear will limit top speed but now youll be able to move 2 houses one with idi other with the 2speed those 2 speeds in low will pull anything and the abality to split gears makes hills with load easy
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
Yeah I think i'm going to stick with plan A and just rebuild her. Some day I will build my semi pick up.
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
got some stuff done I pulled the frame out and washed her up a little
I pulled the tanks and got the front end out.
I had to show off the new BIG RED thats not so red lol
Look its the stock hood:D and she'll have all the stock crome!
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
updates:sly
I pulled the wiring and fuel lines
Pulled the bent rear end
I also started wire wheeling the frame to :sly
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
I just ordered a 3" body lift for BIG RED:sly I also got the under coating for the bottom of the cab.:D
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
Got some wire wheeling done today:D
I still have a LOT to though cookoo lol
Gettin er nice and shinny, looks real good so far. Don't know how your going to finish it, but watch out for flash rust, can happen overnight. If your going to paint the frame it would be a good idea to prime it when your through for the day. Hope your using a face shield doing that, those wire wheels will throw off small wires, don't hurt going in, hurts like hell coming out.
Hey, hows the Salmon running this year?
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
I'm priming it before I paint it and I know all to well about the flying wire lol No worry's i'm using a shied;Sweet
