Belt tensioner question
Chadillac
Lakewood WA
Got it out! Looks like the plate that compresses the top to the bottom completely snapped. Should I replace the idler pulley since this thing had wedged itself against it?
Chadillac
Lakewood WA
The bolt that holds the idler pulley on is a T-50 regular thread. The bolt that holds the tensioner to the block is a 13mm.
ttman4
Last Nite's Dream..
Yes it's not snowing LOL so I went and cked mine & you're right. Idler is T-50 with a big flared head bolt.
My tensioner to block is 13MM
I think I'd consider replacing the idler pully. My Orilieys was about $35 for new idler pully #38015 as well as $35 for Tensioner pully alone #38005. NAPA was lots higher for both.
I ordered from Amazon new complete Tensioner for $59 #38270, Orileys & Napa was close $100+.
Also I noticed the Amazon Idler pully #38015 was a$22
ON EDIT: Depends how quick you need get going, but Amazon fairly quick......also My Amazon prices was with Prime......
lotzagoodstuff
Carmel, IN
“Got it out! Looks like this thing is a P O S”
There: I fixed that for you ;)
If you don’t change the idler pulley, and it throws the belt and busts another tensioner or fan clutch, you will be mad or sad. Change the idler.
Chadillac
Lakewood WA
Yeah I needed it done asap so the instock tensioner at o Riley was 109 and pulley was 30. So I got hosed for needing it done now. Everyone else was getting it to me by the 15th or later. Beats paying a shop to do it I guess.
And thanks guys for all of your insight and help. This really is a great forum for people to keep these old trucks on the road.
Chadillac
Lakewood WA
It’s Gates part# 38270. Seems ok. It has the exact same stamping as the one that failed and that one had at least 80k on it
Wildphilhickup
Texas
I've got a 95' OBS. Only had belts wear out. There is an upgrade to the later model, "dual" Tensioner. I upgraded mine. Motorcraft part is still available. There is a Ford bulletin on this (98-23-14). And there many You Tube videos on this.
lotzagoodstuff
Carmel, IN
This is good info, but not for this post or the IDI forum. The “dually” tensioner is a great 7.3 Powerstroke update (just did one in my 95, pics attached) but unfortunately it’s not applicable to a 7.3 IDI.
pwillis
