Wouldn't cleaning out sludge be a bad thing for old diesels losing oil pressure with worn parts?
I would like to experiment with this stuff on my old vw diesel with some oil consumption and blowby.
That's a myth,that;s about like saying it's a bad thing to take a crap, you should just leave all that stuff in there cause it's holding all yer old parts up Your VW diesel will love the stuff, I've used it on a bunch of VW industrial diesels.Results were nothing short of amazing.
Ok y'all I got some of this liquid gold on it's way. Question is I leave Friday for a 9 day elk hunting trip. I'll be pulling doubles roughly 250 miles each way and 8 days of unloaded use, uber cold morning starts and low speed all tire chain driving. Is now not a good time to be tossin this in the crankcase?
You should be fine. THis stuff doesn't go in there and start knocking big chunks off, It works so slowly, you can barely notice anything happening. For only 500 miles, that's not much of a trip. Only reason I could see for waiting till after the trip is over would be you are going to have higher blowby while pulling those loads and you might end up burning off more of your expensive cleaner while hard pulling those grades before it has a chance to get soaked into things, so in retrospect, you might want to wait until you get back so it has a chance to work it's way into your engine while it isn't under load.
Auto rx installed. Man that stuff has a seriously pungent smell to it
yep. pretty thick to aint it.
Thick like molassas, I heat it up before pouring it in or some will stay in the bottle.
Some one asked about "repeat" if that means do it again. Why hell yes, do it again, what else would REPEAT mean. I named my two sons pete and repeat.
