Ok, after searching, I've found that most threads about cold starts are during deep winter conditions and glow plug issues. My situation is different.
Just purchased an '89 F350 16' U-haul box van with the 7.3 IDI and C6.
I purchased the truck at 8pm in 10 degree winter weather last week. It was frosted over, owner said he hadn't driven/started it at all that day. It fired right up after the "wait to start" light went out, and idled a little rough for about 30 seconds then was fine.
The past two days have been 45 - 55 degrees out, late morning. Each time I've tried to start it, it cranks and acts like it wants to fire, but won't until I hold the throttle wide open. Then, it'll start and run, but barely - very rough idle, mis-fire sound at the exhaust and BIG amounts of black/gray smoke until it clears out about 2 minutes later and only if I revv it up a few times to "blow it out".
Glow plug issue? Leaking injector(s)?
I have about 20 minutes of seat time in this van (driving home after buying it) so I don't know if this has been a problem in the past, but sure is frustrating that it has this problem now and not when I looked at it before buying it.
Thanks in advance guys!
