Got a set of 8 plus one of the AC12G glow plugs for the 5.7 GM diesels, tested them for quality.
Test Details
Ran each one on a charger set to 6 volts/6 amps for 10 minutes each, attempting to cook off any moisture that may cause swelling.
Then ran the survivors at 12V/6 Amps for a minimum of 45 seconds.
Results:
Each one that failed, did so on the 6 volt setting inside of 25 seconds. They cooked off with a .22 cal type bang and continued to operate.
The ones that passed the 6 volt setting also survived the 12V testing. Tested one of them out to 90 seconds with no failure.
I will be running one at 12V/6 amps to failure, will update when results are in.
It appears that if testing the units prior, the survivors will take a huge amount of abuse. The dead ones can be returned for replacement and retesting.
EDIT: Just checked the one for testing to failure, 10 minutes at 4.5 amps of draw (same at the start of the test) and no swelling or cooking off.
In total, 4 of the pack of 8 survived. The 9th failed immediately, so a survivor was used for failure testing.
2 or 3 trips to return the bad ones should result in a set of AC12G that will melt the wiring harness before they fail.
Test Details
Results:
