210Tumbleweed
A little late to this party...er...uh...Did these caps ever work...Hello?
i was going to cut up a set of R&D rails, and chuck em up on a lathe, and turn them into tittyed caps.
but the damnest thing happened, i installed them right, and they dont leak.
installed the injectors on the rails before i installed the injectors, was kinda awkward but it worked.What did you do different to get them to seal?
a real machinist might scoff at you but i am sure you could make the caps on a drill press with the right size drill bits. i have successfully done other parts this way that sealed on an o-ring.
