Can't figure out where all the oil is going. Changed the CDR with a brand new one, no leaks, no oil mixing with other fluids, no signs of oil in the exhaust. Doesn't make any sense too me where it could be going. Truck has some blow by at idle (if cdr hose is covered, will leave some traces of oil on a rag when I hold it over the end of the hose) but blowby goes away completely atleast no traces of oil on rag or hand while holding it over cdr hose at about 1200 RPM or higher. Truck will use about 3/4 - 1 quart every 100 miles.
The truck runs great, has plently of power, idles great and no abnormal knocking or other noises. Starts up within the first 3 seconds of cranking whether it's sat for 3 days or driven 100 miles and hot. Truck never runs hot, always stays at the low end of " C " range. I just bought the truck and don't know the complete history but it supposedly has 145K original miles. Unless I have a Turbo seal out and the oil is being burnt through the exhaust (which I hope that's all it is, far cheaper then rebuild or new motor) I am at a loss.
I don't see any leakage around the turbo, so I kinda doubt that is the problem. I'm thinking rings or valves ( $$$$$
) so that's why I'm thinking rebuild.
If anyone has any other idea's I am more then open for suggestions. I know it's a diesel and it will burn some oil but not almost a quart every 100 miles.
