GENIUSLOERTS
I noticed yesterday when pulling out into traffic and getting the truck up to speed with the flow, that there is a vibration around 2k. I went and read through 4 or 5 threads this morning to get an idea of what it could be. I didn't drive the truck today so I will have to wait til I get home to check out the simple things like the water pump. I just replaced my return lines so no leaks up top, but since then(and it was doing this before aside from leaking lines) I have had it do the start and run for 5-10 seconds alright then get rough and die and have to restart. I'm guessing my water pump being worn out isn't the problem and that it will be related to fuel delivery. I don't have any smoke except when i get on the skinny pedal to get the thing moving, and then it only puts out minimal black smoke.
Any thoughts?
I have only had the truck a few weeks. It was previously a gasser swapped to diesel. PO/swappie said engine only had about 180k on it. he used the engine/trans out of a single cab to go in the crew.
it's a 7.3 n/a 5 speed 4x4.
Any thoughts?
