doctordiesel
Tips on removal and repair of hopefully just the oil cooler anybody done one recently ?
I have searched the vin number and the build code came back as 1987 . what makes you think I have the year wrong ?
Just did mine. It's not a nice job. Very messy. What you need to make sure and do is take the coolant drain out of the side of the block. This lessens the mess some, since when you pull cooler off, coolant AND oil goes all over the place.
Also what makes it easier for some of the bolts in the front is to put a slit in the inner fender, and fold it back some so you can get a ratchet and socket with some very long extensions in there to loosen two of the bolts on the front.
And you do have to take the motor mount bolt out on the driver's side and lift the engine. Just a little bit will do it. And then you can wiggle and twist it out over the crossmember.
Make sure you spend lots of time sitting, laying or whatever in all that oil and coolant, carefully scraping the gasket surfaces on the block to make sure they are clean.
