1968 f250 2wd 360 to 4x4 6.9 swap
Discussion in '6.9L IH & 7.3L IDI Diesels' started by 68f2506.9, Oct 28, 2016.
  1. 68f2506.9
    68f2506.9 Full Access Member
    53
    Oct 3, 2016
    PNW
    Used 1/8" flatbar 20170902_163848.jpg 20170902_163848.jpg 20170902_164511.jpg
  2. riotwarrior
    riotwarrior Supporting Member Supporting Member
    52
    14,582
    249
    Looking good....patch work is great....keep up the hard work and thanks for sharing
  3. Thewespaul
    Thewespaul Supporting Member Supporting Member
    1,415
    352
    Jul 27, 2015
    bulverde texas
    Yeah that body work ain't fun
  4. 68f2506.9
    53
    Oct 3, 2016
    PNW
  5. 68f2506.9
    53
    Oct 3, 2016
    PNW
    My radiator came, mounted the core support and looks like I canmove the motor forward 2 inches and still have 1.5" to the core from the fan. I called Justin from R&D today and I am going to buy a stage 1 kit and mount my hx35 and use the banks intake hat for my turbo system. 20170905_173509.jpg 20170905_180706.jpg 20170905_180654.jpg
  6. 68f2506.9
    53
    Oct 3, 2016
    PNW
    Did some work with the fire wrench to fit the idi in there. Still need to order the stage 1 from justin and see, but there is much more room behind the motor now and the cab bolts to the mounts. 20170915_201635.jpg 20170916_105117.jpg 20170916_204716.jpg 20170916_204724.jpg
    Still have a lot of cleanup to do and box that crossmember in.
    Thewespaul likes this.
  7. sjwelds
    sjwelds Full Access Member
    1,070
    56
    Dec 30, 2013
    Central KS
    If it was me I would throw additional plating on the verticals below the cutout and 4" or so each way wider, as well as boxing it.
  8. 68f2506.9
    53
    Oct 3, 2016
    PNW
    Yeah, I am building a crossmember to hold the engine mounts with like 6×4 tube or c channel. It will be supported.
    sjwelds likes this.
  9. 68f2506.9
    53
    Oct 3, 2016
    PNW
    Got the engine and tranny in the body and lined up with the tcase, tacked the mounts in, now its back out and I am bracing the mounts with 1/4" plate, and rebuilding the crossmember. 20170923_112148.jpg 20170923_112202.jpg 20170923_112410.jpg
  10. Tristan
    Tristan Full Access Member
    46
    158
    21
    Jan 21, 2005
    Federal Way, WA
    Looking good!
    Are you in the Puget Sound area?
  11. 68f2506.9
    53
    Oct 3, 2016
    PNW
    I am near Bellingham, whatcom county.
  12. Tristan
    46
    158
    21
    Jan 21, 2005
    Federal Way, WA
    Beautiful area, I don't get up that far North very often.
  13. 68f2506.9
    53
    Oct 3, 2016
    PNW
    Made some engine mount progress. Need to brace with 1/4" plate.
  14. Thatoneguy
    Thatoneguy Full Access Member
    479
    99
    Jul 10, 2017
    Boerne, Texas
    Good stuff man. Look forward to seeing some pics of the welderin!
    Sent from my VS980 4G using Tapatalk
  15. 68f2506.9
    53
    Oct 3, 2016
    PNW
    20171014_161516.jpg 20171015_150321.jpg 20171016_174859.jpg 20171016_174859.jpg 20171016_180349.jpg crossmember boxed in. The angled side peices go to the bottom of the member and are welded solid.
Share This Page
