scsmith42
I have a '90 F250 2wd 7.3 idi project truck that I'm bringing back to life (been sitting in a barn for several years with a bad oil cooler), and ultimately intend to mate it's front half to the rear half of an '82 F350 dually with flatbed dump that I have. Truck will be used here on the farm but will see occasional highway use. The F350 has 4:11's in the back. Not sure about the F250, but it's tacking around 2,400 rpm at 65mph so probably 3:73 or 3:93.
The 250 is in nice condition and (now) runs well.
What are the best options for adding a manual overdrive (auxiliary transmission) behind a ZF5? I've got to redo the driveshaft anyway when I do the swap so adding in an auxiliary should not be a problem. I knew a guy that installed an old Brown Lipe auxiliary transmission behind a late 70's F350 back around 1980, but those transmissions are getting hard to find.
Seems like most of the auxiliary transmissions available are for Class 7 or 8 trucks are way overkill for a F250 / F350 sized truck with a 7.3 idi.
Advice welcome. Thx.
Scott
Scott
