CDX825
filtration nut
The gas oils are the ones that took the hit the hardest.
Diesel oil still has at least 1200 ppm of zinc witch is what is needed for flat tappets but our engines are not affected by this.
The ZDDP number have been reduced but other things have been added to make up for it. Some of witch will not show up on oil analysis.
The CJ-4 oils also have a greater soot retention abilitys because of the new engines using EGR systems.
TBN retention seems good to from what Ive been seeing.
If your not convinced have some oil samples sent in of new and used oil and go take a look at Bob Is The Oil Guy forums.
