Yeah!!! 400K!!!!
Metalmacguyver
Plymouth MA
The truck turned 400K today, but not according to the odometer......
Can any one explain why this happened?
Russ
Idont do injectors
New Brighton PA
I guess the bean counters couldn't afford any more numbers. Congradulations !!!!
Smokey73
Peeltown, tx
maybe you should try filling it up a little more often, looks like you're running a little low on fuel
Look under the dash, I believe you havs a stripper under there. You look young, so only do it with one eye. :D
Hot damn , keep her rolling. :yell: :thumbsup:
Metalmacguyver
Plymouth MA
Naww, I got to fill up on some one else's credit card so I filled both tanks. The rear one leaks so I am running it as low as possible. Most of the time I run off the front tank.
discbrks
Columbus, GA
Aw man!! Ya beat me to it! And I'm SO CLOSE.... Another 750 miles and I'll be there with ya!
Shadetreemechanic
Monteagle, TN
My understanding is that all the ford odometers do that. Why they couldnt't figure out how to make a 4 in that column is a mystery.
Metalmacguyver
Plymouth MA
My dad was thinking that if they only used a 2 bit memory slot for the hundred thousands slot, then it would only be able to count 0, 1, 2, 3, and no higher.
Thanks for all the comments!!!
subway
be nice to the admin :D
York PA
how to legally roll back the odometer 100k:D just over 200k more for me
F350farmboy
The Hornet
N.E Ohio
Thats the same thing with my brothers VW passat...except it goes back to 0.....we found this out AFTER we bought it thinking it only had 150k......
Diesel JD
Gainesville, FL
At least your later trucks have room for a 100,000 place, my truck just rolled over 200K(I think) and it rolled back to 0 as my 89 Ranger also did.
mrthechampion
