WMO (synthetics and/or gear oil ok?)
CaseyJones
I have searched the archives here. I already see that high concentrates are a bad idea. Is 2-3 gal:20gal diesel a bad thing, is that lean enough to not harm the engine in any way? I want to burn it but not at the cost of shortening engine life.
Can I burn gear oil and synthetic ATF/Gear oil the same as conventional motor oil like the Rotella that I just took out?
Thnks
Diezel_Cowboy
It's not like a real ***!
A little place called "nun a ya binez!"
Thnks
I'd say if you wanna burn it and not shorten engine life you are dreaming.
