7.3 idi head gasket or oil cooler fail?
Carson E
Alabama
I need advice bad. I just finished the engine swap/upgrades. I’ve got a 1990 f250 with a 93 n/an engine that I’ve resealed added head-studs, 90cc pump, stg1 injectors, cdd 61mm turbo kit, and e fuel setup. The engine has maybe 5 minutes of run time on it and has filled the radiator with oil/coolant mixture and oil pan with oil/coolant mixture. I resealed the oil cooler but could it be possible I’ve messed up and cut one of the o-rings putting them together? Or would it be the head gaskets. I’m hoping it’s the oil cooler and not the heads. If anyone could share some insight on what it could be please do so. I’ll be draining the oil and coolant and I’ll pull the oil cooler as soon as I get the chance. If anyone has an idea of flushing the turbo out and flushing the engine out with anything better than running diesel through it please share any ideas, thoughts, or suggestions on what I need to do. Thank you.
Most likely it's the oil cooler. There's no pressurized oil that runs through the head gaskets. It's delivered through the push rods.
For the turbo, you could remove it and use some kerosene to clean it out. Although you'd run the mixed oil through it when you run the engine. You could keep the turbo off until you've flushed the contaminated oil out. All you'd have to do is run the oil feed line back into the valley pan where it drains after going through the turbo. The open exhaust will be loud, but it won't hurt anything. I wouldn't rev the engine too much if you go that route. Just run the engine for a few minutes and the drain the oil again.
DirtyWood
Earth
Hopefully it's just the oil cooler. I've done a couple oil coolers and had success using lots of either assembly lube or Sil-Glyde on the o-rings and housings. I also use body weight and some creative bracing to reassemble.
I haven't had to do it--knocks on wood--but I've read a lot of people recommend Calgon for cleaning out the cooling system.
I had the OC fail several years ago, I thought Head Gasket, and 3 guys came back, "Oil Cooler".
Started a Thread, but so far haven`t found it.
here is one where I posted some info on another thread about the OC.
ROCK HARVEY
Dayton OH
If you have fabrication ability the service manual has instructions to make an oil cooler pressure tester. I can post pics of the instructions if needed.
Here is a good read on the Oil cooler R&R,
I went through this about 6 years ago. I posted it over on FTE before I Discovered Oil Burners, and
signed up here. Did the R&R in January on the patio between Snow Storms.
The link is in the above link in Post# 9 also.
Carson E
Alabama
Thank you all for the tips. I had rebuilt the cooler about 4 months ago when the engine was still out of the truck. I used parts fluid to clean it out and cleaned all of the surfaces for gasket and I used 400 grit sand paper to clean the surfaces where the o-rings set at and thoroughly cleaned the cooler. I never pressure tested it as I didn’t have a way to do so. I also used a press to put it back together and I remember one of the heads cocking over to the side and I started the process over again and made sure it was straight. I hope that is the cause of me clipping an o-ring. I used a heap of Vaseline to install it so I wouldn’t damage an o-ring. I will probably just re use the heads and buy a new bundle just in case the other has failed. I greatly appreciate everyone’s time and effort to help me with this issue.
When I did the end caps, I did one at a time on my 20 ton press.
One end pushed right on.
The other one, cocked like you mentioned. Had to reset it several times.
Used Syl-Glyd for the lube.
The other end when I finally got it to stay straight, made a BANG when it popped on.
Thought for sure I broke something.
Well it`s been on 6 years and now up to 374600 miles and no leaks.
I had some Hard Wood block/pieces I used to push against in the Press.
david85
Campbell River, B.C.
Another vote for the oil cooler. Been there, done that. In my case the aluminum end caps had some corrosion where the O-ring landed and it took several tries to get it sealed up properly. In the end, I used a small rotary tool to clean up the aluminum surfaces. Made a pressure test rig with compressed air and submerged in water to make 100% sure I killed the leak. Been good for several years now.
DirtyWood
Earth
The fun thing about the oil cooler is that it seems like everyone ends up doing it just a little bit different from the next guy.
hacked89
Bucks County PA
If you’re looking for guesses I’ll x3 the oil cooler. Pry heads off with flathead, clean up surfaces and back together with petroleum jelly. 20 ton press and should be zero resistance on it. If it feels like it “pops” on, that’s the oring breaking
ttman4
Last Nite's Dream..
Several yrs ago I posted about some my "OIL COOLER rebuild BOO-BOOS"
@genscripter posted about post #3 how to rebuild & test oilcoolers.
I posted how I built an OC tester to test oilcoolers several years earlier, about post #11 & post #14, as well as several other OB members posted lots of good info. in this thread.
david85
Yes, it really shouldn't take that much force. When I rebuilt the engine over a decade ago, I used a shop press (very carefully!). But the more recent repair was done with a dewalt trigger clamp, like this one: https://www.homedepot.ca/product/de...ger-clamp-w-3-75-inch-throat-depth/1000813525
The last couple of times I did rebuilt one, I could get one cap on just by pressing down with my body weight. For the other end (I don't remember which was which). I used a ratchet strap around both caps to keep pressure on them and then used my dead blow hammer to tap the cap the rest of the way on. It didn't take much either.
Kenl
