I just got back from a couple hour trip in my truck and it ran very well like it always does and then when I got home to park it in the drive way I gave it a quick rev and it sounded fine but when I did it again, the RPMs only went to 2,000 and it sounded like it was hitting the rev limiter and smoke was pooring out of it. I done it again and the same thing, it revved to between 1800 and 2000 and started surging like it was hitting a limiter and smoking like crazy. At idle everything sounds great and smooth but if you rev it up to about 1800 it acts like it doesn't want to go anymore and smoke the entire time. I am thinking it must be injection pump issues although I am unsure why it let go today, it was running perfect prior to that and it still idles and drives fine below 1800 rpms. It has a new filter and fuel pump is pumping as normal and it doesn't seem like it is starving for fuel because of how it will smoke when you rev it. It is actually smoking like a pro stock or something when you hold it down right now, not sure what the deal is.
I went outside and tried it again to make sure that it wasn't just a fluke and it was still doing it and this time it would not rev over 1500. BUT, I figure it out, read next post.
