i found everything i needed for the hydroboost swap in the junk yard. cost me 50 bucks for the hydro unit and all lines. did grab the pump, but found a reman pump was only 50 bucks also.
i found mine, looked brand new. like it was just replaced. no dirt on it at all. same with the hoses. the rest of the truck was filthy.
hell, my truck was built from the junkyard and lowes.
- Hoss, I got news for you.. You're not. You're trusting your brakes to something as fickle as a belt- just like everybody here except the folks that are running electric vacuum pumps.
Hey Billy,
No, at the moment I can't tell because there's so much shiny oiliness under there that you can't tell anything. The weather is supposed to warm up this weekend so I'm going to put some simple green in the pressure washer and blast it all clean, dry it all off, start it up and lay under there and watch to see what drips in my face from where..![]()
vacuum brakes-1000 lbs of braking force.
power steering brakes- 2000 lbs of force.
My numbers arn't exact but the point is hydroboost is about twice as powerful as vacuum assisted brakes. Ive also pulled the belt off of my vacuum pump. just plain dont need it anymore since my a/c is broke, no cruise and no slush box.
The point is instead of spending money on new vacuum parts, why not go ahead and convert to hydro boost. This was my reasoning when I would start the truck up in the morning with no vacuum. Instead of hunting down the leak, I went hydro. sounds better too with that hydraulic whine.
