Whistling noise
RenoF250
Sierra Foothills, CA
My truck has started making a new whistling noise very similar to the sound of a pressure cooker. From the drivers seat it seems to be coming from around the air filter. The odd part is it seems to only do it when cold and only ~1,600 rpm. I can see I have an exhaust leak on the DS so I am thinking that may be the culprit and it only does it when cold because the EBV is on.
Any other possible causes I should investigate?
dyoung14
Is getting worn out
spencer,tn
They EBPV will cause some pretty unusual noises
wils2527
Dumb Engineer
******* Pines, Ca
So Reno250, you are in the Sierra Foothills? Where at exactly? If you need any help investigating I'd be more than happy to swing through and help out.
mydixiewrecked
