which return line kit ??
gendoc
lowest bama
for my 94 f250 7.3L-idi/na....i see many advertised on a few different suppliers websites.
which has been good for yall ?
thanks :cheers:
Cubey
Van dweller
I used an O'Reilly sold kit on my F250. On my RV, I just used o-rings I ordered as extras for the F250, bought the hose by the foot from AutoZone, and used a combination of the F250's old caps and the RV's old caps depending on how they looked condition wise. No return line air intrusion on either one since.
cozinsky
Iowa
Delphi 7135-264. I used that kit on my truck and its excellent quality.
chillman88
Central NY
I would send you to Russ if you've never done it before. I personally just ordered a package of Viton o rings and did it myself with new hose and the old caps.
Whatever you do, make sure you liberally lubricate the o rings and caps before putting the caps back on. I use wheel bearing grease and it works good.
If you buy a set with new caps, look them over closely. The inside should be clean and smooth. I've seen some with casting flash from poor QC and they needed some cleanup before installing.
Cheaper kits will come with less durable o rings. Viton is the way to go and I believe is what Russ sells in his kits.
Stu Bailey
Idaho
I’m going to second what chillman and others will say, you gotta use viton o rings and spit all over those things when you put them in. What I really mean is lube them up nice and good. Buying from any of the above suppliers and doing that should have you on the road trouble free for years to come
Kevin 007
Full-floater
Nelson BC Canada
Do not use GB Remanufacturing injector install kit. The caps are too large in inside diameter.
I have had luck with a few of their other products, but not their return kits
Ky85
West
Yeah what they said.
I used a napa kit, o rings are questionable a year later. Wiggly but dont leak
Lube em up plenty
Farmer Rock
Glen Rock,PA
I used the Delphi kit a couple times. I got them from autozone or napa. They seem good after a couple years. Other times I just bought the fuel line and O rings, and just reused the caps since they were good. From now on, I am using the viton O rings either way, and like @chillman88 said, be sure to lubricate them good with grease, vaseline , or thick oil of any type.
Rock
Cubey
Van dweller
Whatever you do, make sure you liberally lubricate the o rings and caps before putting the caps back on. I use wheel bearing grease and it works good.,
I used petroleum jelly from Dollar Tree on my truck and RV and it worked well.
Fredrickson
Newburgh, NY
To save someone/anyone the time, here is the link to buy viton rings from mcmaster-carr
(.. and put the keywords in this post for anyone searching for this later.)
Part number and link for the viton rings.. https://www.mcmaster.com/9464K24/
Chemical-Resistant Viton Fluoroelastomer O-Ring, 3/32 Fractional Width, Dash Number 111,
Packs of 50 viton o-ring, o ring, mcmaster, air intrusion, return line, caps
The_Josh_Bear
Western WA
And don't forget that McMaster-Carr charges about $11 to ship that $8 pack of o-rings. cookoo
But of course they can't be bothered to put the shipping cost anywhere in the cart or checkout process. I emailed them once about it and they replied like it was so normal to hide the shipping cost. They said I could email them about it for every single order...what?! That was probably 5 years ago and nothing has changed. I love their site and parts and dimensions and all that, but they refuse to do the basic shipping cost per order. Clearly, it drives me nuts. -cuss
chillman88
Central NY
It's not like every other company we've ever dealt with will at least estimate the shipping during checkout :rolleyes:
