Which Oil Pump should I use? (With Video)
genscripter
Inglewood, CA
I have two oil pumps both from 7.3 IDI vans. One spins freely and one spins kind of clunky. Which one should I use?
genscripter
Inglewood, CA
I thought about that too, because the clunky one seems a bit odd. But I just wanted to check with the group and make sure that it wasn't like a fan clutch, which in that case spinning freely is a sign of a worn out fan clutch.
The oil pump should spin fairly freely with no oil inside. I'd say use the first one in your video.
Kind of wonder why opening up the pumps was not the first suggestion... BTW EVERY oil pump from ANY idi fits all 6.9 and 7.3 idi engines. And the oem pumps are better than the Melling.
