I cannot find where to get the 7 tooth worm gear that slides onto the output shaft in my transfer case. The one that is in there is all mangled up.
Same here, I was really suspicious about quality but they ended up being fine. Comes in a 5-pack which I thought I would never use, but then I changed gearing and tires and ended up swapping out so it was worth it.I got mine on eBay. There are sets as well as single units depending on the color you need
Make sure the driven gear is still in good shape, any damage or wear to the point that contact is reduced will wear out that drive gear pretty quickly$62 dollars beats unobtainable IMO. Thank you!
