Wheel spacers for duals.
Tomstill8569
Campbell, TX
I have a simple question and I cannot seem to find the answer to it. I need a spacer between my duals for tire space and I need to know if I need a hub centric spacer or not.
ihc1470
Idaho
What style rims do you have will determine what sort of spacer you need. Might post some pictures. What size tires are you trying to mount? Is this a true dually or a conversion like I run? If a very thick spacer you will probably need to have longer studs installed. How much clearance do you have now?
u2slow
bilge rat
Coastal BC
The factory wheels are hub-centric, so the spacer needs to be. The hub gets smaller once you're 1+" away from the lug flange.
