divemaster5734
Have searched for an exploded view of a '04 rear suspension to no avail. Tried to order a pdf download, then got an email it would be sent snail mail in 7 days.
Am having an issue with the "bottom out" spacer position.
Everything I've read to date said it goes below the leaf springs.
Then I realized that makes a huge gap, which looked bigger that the leaf spring to body gap.
It's actually around 9 1/2" to the stopper from the spacer.
I stuck the tape measure there as a pointer.
The gap to body is actually around 7" to the U bolt ends.
I'm thinking the spacer needs to go above the springs.
There's no manual for the C350, and all end ride heights are unknown.
That said, the truck is on stands and mostly level.
As it sits, the back of the truck would sit at least 3"-4" higher than the front, even giving the approximate additional 2" that will come with the RS kits and '04-'08 springs.
I'm sure I'm over analyzing, but anyone know what the normal distance is from stopper to bumper?
Moving it to above the springs should be around 7" travel from normal ride.
Thanks
Thanks
