Flywheel housing for SAE trans
superkonr
Idaho Falls, ID
Anyone know a part number for the flywheel housing out of a big International box truck that mates an IDI to an SAE pattern trans? Has the big side mounts on it. Can't find anywhere locally that has any of this stuff... Thanks!
EDIT: Found it...
The T444E SAE2 flywheel housings are:
1821697C1 (this one might need modification to be able to access the flex plate bolts)
1821697C2
1821697C3
To use with Allison SAE3 bell-housings a SAE2->SAE3 reducer+spacer ring is needed:
480861C1
3585126C1 (maybe)
The T444E flywheel housings need this spacer ring. You can’t just mate an SAE2 Allison bellhousing straight to the SAE2 T444E Flywheel housing without a spacer. To my knowledge there isn’t a SAE3 T444E flywheel housing.
Crank spacer/counterweight:
182587C1
Flex Plate:
1833796C91 (kit)
TC to flex plate spacer:
1827180C3 (kit)
