Blind Driver2
You guys are making me feel really good about my truck
if it's you.......YES.Does the driver sitting in the seat count?![]()
My windshield wipers won't park. I have to turn them off at the right time to get em to stop where they belong. The intermittant wiper wont work. They run like normal.
Still broke -
Flatbed needs mounted (orginal bed in VERY bad shape, cheapest bed I could find)
Custom filler necks for flatbed
Fuel heater leaking/connector falling apart
Steering gearbox or pump leaking (will replace both)
Steering shaft needs replaced
Shocks worn out
Carrier bearing for rear drive shaft
Headlights fogged over
Oil cooler possibly leaking externally (comes down from above filter but nothing visable above cooler)
Could use front springs but Ill probbly wait for D60 swap first
Front seat needs restored
Cant read screen on factory orginal radio (still works great even with bent antenna)
Front brakes are nearing replacement time but trying to wait on D60 swap (will do rears at same time)
Cab needs painted/still partly dented but much better
Recently fixed -
Valve Cover gaskets
Lift pump
Injectors
Injection Pump (NMB2 Turbo cal)
Exhaust (4" straight pipe vs ending at DP)
EGT gauge replaced (inop when I got truck)
Added boost/tranny temp (have coolant temp gauge but havnt installed sensor yet)
Right fender and door replaced
Is lmcs relay mod just a direct plug and play type thing?
the ladies love that!)
Still a few kinks... but slowly workin em out.
