Optikalillushun
What I've been up to... (Updated 11/12/11, start up vid added)
After letting my truck sit most of the summer with work, now i have time (laid off) i can get some much needed work done before winter. So here is what i have done up to now.
Back in March i needed new batteries, and being one to never let anything go i figured ill upgrade to some G31s. So i bought two CAT G31 batteries from my local Ford dealer since i had a hook up on parts when i was working. I think they are 1000cca, and i paid around $160 for them. I also removed the battery cables, cleaned them up, repaired any damaged ends and replaced the terminals with lug style with solder plugs and HD adhesive shrink wrap. Then i cut two old floormats up to make flaps for the positive terminals so it doesnt short out on the hood.
Next fast forward to about July, one of the few times i drove my diesel to work it left me stranded. So it was time to replace the starter. Bought a NEW gear reduction starter from Advance Auto for about $180, and had it R/R'd in like 20 minutes.
After that nothing much happened until a few days ago when i got a bug up my ass to finally get goin on it. So now my next project is to upgrade the headlight wiring. I found this harness at the junkyard a while ago and it came with everything i need to set mine up, just have to add some lenght of wiring because i had to cut out some chaffed parts. I also found these really nice relay socket/pigtails and fuse holders at the Carlisle All Truck Nationals a few years ago. I still need a pic of the female plug that plugs into the old headlight harness to act as the turn on for the relays.
Then in no particular order:
- 3G alternator with bussman fuse holder
- R/R the vacuum pump
- R/R the PS pump
- R/R all the belts
- Reinstall the rear tank and repair the damaged fuel lines going to the tank
- R/R the fuel line olvies
- JB Weld the fuel heater port
- Install the high idle mod
- Install the running light mod
- Install the pyro (may not happen)
- Have the exhaust redone
- Allignment
- Shocks
So at least i have stuff to keep me busy. Ill get some pics of how this round of repairs/mods go as i get them completed.
I do have one question, how to i set this lil ****** up? Its the equalizer for the parking brake.
I have it adjsuted so its taught but my truck will still move with the parking brake enguaged. Obviously i have to re-adjust the brake shoes but how taught does that need to be? Probably a stupid question but i never delt with one of these before.
(not the one i am using, but similiar)Then in no particular order:
- R/R the PS pump
- R/R all the belts
- Allignment
- Shocks
