what did you get youre idi with income taxes?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
well i'm gonna get an ox locker for my IDI powerwed scout, and pickup the IH 392 from the machine shop for my '74 scout! ;Sweet no replacement for displacement!
-Jon
429idi
Layton Utah
I got a tank and brackets for my propane injection. And an he351ve turbo to play around with.:sly
88beast
pa
429 my idi is getting a hx35 but i googled what you got and that looks interesting one guy set it up as an engine brake is it a varriable geometry turbo?
429idi
Layton Utah
I had an hx35 but I sold it, I now have an h1c and an h1e that I was going to compound, but decided not to because the h1e map I was reading was using si units and I didn't realize it till I bought the turbo.:mad:
My turbo is the vgt, I'll have to set the nozzle control up manually, so no exhaust brake till I can buy the electronic stand alone. I'll start a new thread about it when and if I get it done. Watch for it in the next month or so.
What turbine housing are you going to use?
Sorry about the hijack
Diesel_brad
Dunce
gilbert pa
Even getting 500 hp out of a psd would be kinda hard dont you think. Injectors ($1000) and trans mods for the torque. I have just heard that 500 is hard to achieve idk
Not when it will get
H2E modded turbo
4 position chip
250CC injectors
Stealth HPOP
Electric fuel
I/C
H-11 head studs
Comp valve springs
chrome moly push rods
Dual Disk clutch
I will be right at 500 to the tires
93f250idi
strokin
cadiz ky
H2E modded turbo
4 position chip
250CC injectors
Stealth HPOP
Electric fuel
I/C
H-11 head studs
Comp valve springs
Dual Disk clutch
with 250cc injectors wont an intercooler be required to keep egt's down?
88beast
pa
429 im starting out with the stock cummins hx35 17 psi wastegate and ill upgrade from there any housing youd recomend?
RangerDanger
