leswhitt
Up until this point, the majority of my WMO has either been jet black (diesel WMO) or had a hint of red (ATF WMO). This last batch of about 250 gallons came from a place that had their barrels outside and was a mix of hydraulic oil, engine oil, small amounts of ATF, anti-freeze, and rain water.
After letting it settle and draining off the water and anti-freeze, I added 20% RUG and let it settle again. Then I drained it again and only pulled a very small amount of water/sludge off the bottom. I then went ahead and centrifuged for about 18 passes through my PA Biodiesel pressure driven fuge, let it settle again, then sucked off the top and emptied my tote of all but 50 gallons.
This oil has a light/medium brown appearance and isn't nearly as viscous as my regular WMO, it's very thin by comparison. When I dribble it though an open flame, it's definitely flammable. I tried a hot plate test like the WVO guys but the drops were sizzling but then I didn't know if that was caused by the RUG in the mix or true water. Then I thought to put it in a glass jar, and stick that in a pot of boiling water for about 35-45 minutes. The resulting separation was a VERY thin layer of contamination on the bottom, probably less than 3% of the overall volume of the jar. Finally, thinking that maybe it was super emulsified, I poured a measured amount of water into the jar which promptly went right to the bottom of the jar and separated from the oil (within 3-5 minutes).
So what do you guys think? Have you ever had WMO that looks like this? Does it sound like water is still mixed in? I have about 250 gallons of the finished product, about 125 gallons centrifuging right now, and plan to burn this on my family's upcoming 1800 mile Christmas trip and then a 2400 mile trip about a month after that.
