Weird thick smoke before first drive of the day
Christopher Cline
Washington
Every morning never fails if I start the truck and let it idle longer than 3-4 minutes and then give it a small rev a massive thick whitish brown black cloud comes out then it’s clear the rest the day. It smells heavily of burnt oil too. Maybe cdr? I just put a new one on about a year ago but maybe it’s time for a new one again
My first guess would be valve seals. I think that it's rare that a CDR actually goes bad.
It's probably more like the oil gets burned out of the cylinders. It will only seep past the seals with no pressure in the cylinders. The engine only has no cylinder pressure when the it's not running. The oil only has gravity to push it past the seals while even a very low compression gas engine has WAY more pressure in the cylinders.
chris142
SoCal
Don't let it idle? Idling is bad for it anyway. Does it run smooth ?
aggiediesel01
Houston, TX
What can you tell us about the truck? Year? Miles? Turbo or n/a? What do you know about it’s maintenance history? Does it idle smooth at start up? Does the cold idle advance solenoid work?
White smoke can be unburnt fuel or coolant as well. Burning oil usually has a bluish tint. If it’s fuel, maybe you have an injector or two that are not closing all the way until it warms up? Or really poor spray pattern that’s not giving a complete burn until there’s enough heat in the cylinder to light it off.
Adding some of the above information will be helpful with internet diagnostics.
Christopher Cline
Washington
So I bought it about 20k miles ago. N/A newer cdr 5 speed Manuel. I like to let it idle until high idle and advance kick off. Maintenance before me no idea. I do have a spare motor with 150k on it but I’m not ready to swap them yet. Not losing coolant am using about a quart of oil every 300 miles
Christopher Cline
Washington
One odd thing is it will blow black smoke above 2800 rpm no matter how low I turn fuel down. Well aside from it being so low it will barely drive
This may not help with the oil consumption, but instead of turning the fuel down, try advancing the timing to see if that helps with the black smoke over 2800.
Christopher Cline
Washington
Ok I advanced it about the width of the line on the pump it moved the black smoke to around 3,000 and up. Does feel like there is more power now tho. Starts a little harder though. Insta lead of just bumping the starter And it firing it takes about one or two revolutions
macs
macs
Fort Worth / TX / USA
A quart of oil every 300 miles is a lot of oil! Because of that, I think it is probably oil buildup in the cylinders due to faulty valve seals.
Christopher Cline
Washington
Also black smoke ya still there at the high rpm but when I’m working her hard she doesn’t get that awful hot smell. Just normal hot manifold smell
olsen726
