strokemaster
Just got this 89 7.3 idi and I’m more of a Power Stroke guy so I don’t know much about these engines. Takes a while to start up, but with enough glow plug cycles it will. feels like air intrusion to me. But once it’s running, it sounds like it has a dead miss on one cylinder and it’s puffing out white smoke. every once in a while it makes a popping sound or backfires out of the exhaust. It will do this up until it gets to operating temperature. But even then with throttle and without load, it’ll start puffing smoke again and dead missing. I found that it seems to be cylinder seven doing this because every time I loosen that injector feed line the smoke stops completely. And it seems what’s coming out of the injection pump is not as strong as the others and has air. I replaced the injector on cylinder seven with no change. And I did return lines, olive seals, and the new facet pump. Not sure what it could be. I’m just hoping it’s not an injection pump because I’ve already gone through two. Thanks
