Hi all!
Water is leaking on passenger side up near the firewall. Seems to be engine side as far as I can tell. It has left a puddle twice. It seems to be leaking more water today. Does not smell or look like coolant. I ran with the defroster on for about 45min. into work, checked the truck 2 hours later and the insulation around the evaporator? was saturated and there was alot of water on the ground. Could someone give some input as to what is happening. The A/C blows cold and the defroster/heat still work.
thanks
thanks
