redneckaggie
rebel w/o a cause
did you ever replace the vacum pump?
I have replaced every single component except hard lines on my truck. start the truck up with a vacum gauge hooked to it coming directly from the pump. should have 22 in hg within seconds at idle. kill the truck after you note where the gauge is and walk away for 15-20 min and come back to make sure gauge isnt loosing vacum. if that checks good move down the line to the hose right before the booster and check that to check for leaks in the lines(happened to me). if that checks out good and the pedal is firm when you unhook the vacum from the booster then its the booster.
