Which filter element do you use for 1 micron filtering?
i used the water filter housing for the 1 mic filter. i am not sure the part number but the filters were beside the housings in the hardware store. you had several choices that ranged from like 25mic to 10mic to 5 then 1mic. they had everything on the shelf at my local tractor supply. i will see if i can get a pic of my set up then.
50/50 in the winter might be a little strong depending on how cold it is, i started having a little trouble in the thirties with that strong a mix not bad though. 75/25 should not be a problem in the summer though.
i really should get a pyro since oil can burn hotter.......your results may vary depending on your truck. this is all at anyones own risk to. i have never had a problem but i dont want anyone thinking bad of me if you do. i am no expert just offering my advice on what works for me.
