Im sitting here kinda board the weather is crapy and I dont feel like getting out in the wind so I will start this thread. I finally got my engine running that has been built for sometime after fighting some head stud issues. It seems to run great. I was going to pop on my turbo and PSD intercooler but I just started thinking of what I could do to help this thing out. The main goal for me is to keep down my EGT's but still be able to fuel like crazy when needed. Or at least do the best I can. I kept thinking about how much I did not like the crimped ATS turbo up pipe and smallish turbin side. I thought maybe I could help it by adding another turbo. Maybe the extra flow might help EGT's? Maybe I could spool up faster? I am really not sure about much here. I will say Im going to give it a shot and if all else fails just put back on the ATS stuff and call it done.
Lets lay out the game plan and players here.
Truck:
1994 Ford F-350 Turbo Diesel
Extended cab dually
4x4 conversion (no front adapters, using D60 with true 4X hubs for dually)
Engine:
1994 7.3L IDI Turbo Diesel
Bored .020 over Sleeved in 2 holes were the casting was thin.
Stock Rods and crank
Mahle forged pistons ceramic coated on top (stock cp ratio)
Total seal rings
clevite 77 H series bearings
Fully balanced with luk SM flywheel and clutch
Fel-pro gaskets
ARP Studs
Ported heads and intake
Trans:
ZF five speed converted to 4X4 verion
Twin Turbo parts and stuff:
2-1/4" mandrel bend kit
2-1/4" section of straight pipe
3" mandrel bends and pipe
T3/T4 flanges
2 oil feed line kits
Powerstroke intercooler (all aluminum version no plastic tanks)
Hypermax intercooled version intake hat
2 T3/T4 turbos with internall wastegates
I will try and get some pics up.
Truck:
Extended cab dually
Engine:
Total seal rings
Fel-pro gaskets
ARP Studs
Trans:
T3/T4 flanges
