swampdigger
Hi guys, first post here.
I'm considering purchasing an '85 F-250 6.9L. The problem is, the bellhousing for the T-19 cracked around the shift fork. The price is fair considering this, and I would like to buy it. Unfortunately, I'll have to fix it where it sits on the pavement.
I've done many an engine swap, but never with a 1000 pound diesel up front. Myself and a friend were planning on removing the skid plate under the t-case, undo the tranny crossmember, t-cases linkages, speedo cable, d-shafts etc, etc.. and then benchpress the tranny and t-case out in one go.
Will this fly? Or am I going to need to support the engine while doing this?
I'm guessing 50 pounds for the aluminum t-case, and 80 for the cast iron tranny. Sound about right?
Thanks
Thanks
